Market Forge Industries Inc. - STME
Market Forge Industries Inc. STMEA built-in control maintains the operating temperature at a preset level up to 121°C (250°F) for Standard models. The Laboratory models have an adjustable control and may be preset up to 121°C (250°F) or 110°C (230°F). Timed sterilization (0–60 min.) starts after operating temperature is reached. The 103kPa (15psi) operating pressure is reached in a few minutes. The door is self-sealing and cannot be opened until steam pressure is completely exhausted. Exhaust selector may be set for liquids, instruments, or soft goods. Sterilizer features a 0–207kPa (0–30psi) pressure gauge, temperature gauge, low water cut-off, safety valve, thermostatic steam trap, and signal light. Required connections: drain, 13mm (1/2") FPT or 16mm (5/8") O.D.; copper steam exhaust connection, 10mm (3/8") IPS. All models available for operation on single or three-phase, three or four wire system.
Internal Diameter | 16 in |
Height | 27.625 in |
Length | 31 in |
Chamber Depth | 26 in |
Width | 18.75 in |
Tray Size: 12" x 20" x 4"
