Draeger - Narkomed 4
The tilt panel touch screen display provides patient information and system control.The North American Drager Narkomed 4 anesthesia system is a very popular system for anesthesia delivery, monitoring and management. At the time of this posting the Drager Narkomed 4 is one of the most advanced NAD machine available, and is equiped for enhanced critical event avoidance and rapid response. Standard features include all NK2B features plus Touch Screen, Remote Display, SpO2, non-invasive blood pressure, EtCO2 and agent monitoring.
FORUMSView All (9)
0Replies9 years ago | deseo el manual de servicio Reply |
1Reply9 years ago | service manual i need service manual of narkomed 4 Reply |
0Replies10 years ago | Tubing replacement tip I have found a simple trick to aid when replacing tubing on the NM2, 3 and 4's. I use a heat gun to turn the opaque tubing clear. It is best if you have a small diameter welding nozzle on the gun. The tubing is more flexible after treatment. This avoids the problem of having multiple lines breaking as I am attempting to change them one by one. I have found this helpful. I hope you do as well. Only heat the tubes till they are clear, any further runs the risk of melting the tube. Also care must be taken when the line runs past wires or electronics. Any residue displaced should be vented during post replacement testing. All the best, Ron. Reply |
[list] [*] 19.1 vaporizers [*] AVE ventilator [*] NIB [*] SPO2 [*] CO2 [*] Built in monitor. [/list]
Height | 64 in |
Gases | Air, Nitrous Oxide, Oxygen |
Length | 25 in |
Vaporizers (Max) | Three |
Scavenger | Open or Closed Interface |
Weight | 500 lbs |
Inspiratory Flow (max) | 120 L/min |
Vaporizer Type | Variable-bypass |
Vent Modes | VCV, Manual/Spontaneous |
Width | 31 in |
