Toshiba - Aquilion 64
Perfection in Patient CareThe Toshiba Aquilion 64 CT machine is considered the only true volumetric 64-slice CT scanner with 64 detector channels, 3-D cone beam algorithms and volume reconstruction on the market. Automated features in the Toshiba Aquilion 64 CT scanner's SUREWorkflow software enable the operator to monitor a patient's heart rate prior to scanning. Toshiba's 3-D Quantum denoising allows for reducing patient radiation exposure by up to 40% without loss of image quality. Each Toshiba Aquilion 64 CT scanner also features volume reconstruction, enabling you to scan a large volume in a minimum of time as Volume Viewing automatically reconstructs scanned data into the isotropic volume used for diagnosis.
FORUMSView All (34)
0Replies10 months ago | protocols If it possible, please can anyone help me out for Toshiba Aquilion 128 ADULT hrct protocol. my email daryamsk@gmail.com Reply |
1Reply10 months ago | Purchase of 64 slices CT I need to buy pre owned 64 slices CT machine. Contact me baats2000@yahoo.com or on this medium Reply |
2Repliesa year ago | „Error in wedge movement“ Hello everyboda :) i need help please. what that meaning. „Error in wedge movement“, There is also a short noise in the gantry. ThanksReply |
SERVICE COMPANIESView All CT Scanner Companies
[list] [*] Access to a very comprehensive set of advanced clinical applications [*] Precise isotropic imaging of any clinical site of the body [*] Fast temporal resolution [*] 64 simultaneous slices of 0.5mm with each 350ms revolution [*] 256 slices in one rotation with .5mm slice thickness [*] 13cm coverage in patient axis direction [*] Advanced SUREWorkflow software with PhaseXact [*] 180cm long by 47cm wide patient couch [*] 40% radiation dose reduction [*] 70kW HF generator with 400 ms scan speed [/list]
Type (configuration) | Multislice |
Maximum Scan Range | 180 cm |
Gantry (Max. Clearance) | 72 cm |
Image Display | 18 in LCD color x 2 |
Patient Weight Capacity | 450 lbs with option up to 660 lbs |
NEWSView All
TOSHIBA’S ENCORE VeloCT CONSOLE RECEIVES FDA CLEARANCE
VeloCT Brings Latest Dose Reduction and Workflow Enhancements to Aquilion 32, 64 and CX
Aquilion 64
Friday, March 11, 2005 The Adelaide Advertiser reports that a new $1.4 million Toshiba 64/CT scanner, "one of only five being trialled in centres across the globe," has been installed in Adelaide. Toshiba describes its Aquilion 64 system: Featuring the most advanced multislice CT technologies available, the Aquilion 64 is built on Toshiba...
