I came to find out that the system could not boot. When turned on, it shows the normal Philips healthcare and then return to signal lost and become blank. I then had to reinstall the window XP OS. I want to install the embedded system OS but the SIP is not seen. Must the embedded system be installed first before it sees the sip? Please I need a solution urgently. Thanks
Fri May 29 2020
Corrupted OS?
Fri May 29 2020Reply from Ben C
What is the name of the model of the equipment you are working on?
