GE Discovery IGS 730: Rediscover space and movement. Vision and precision in motion
The Discovery IGS 730 image-guided system brings you exceptional imaging, easy patient access and predictable motion in a hybrid OR environment.
Mon May 20 2013
GE Healthcare's Discovery IGS 730: Rediscover space and movement! Vision and precision in motion.
The Discovery IGS 730 image-guided system brings you exceptional imaging, easy patient access and predictable motion in a hybrid OR environment. The system’s gantry can be parked out of the way and you’ll have access to more than 20 advanced applications.
Hear Stephan Haulon MD, Hospital Cardiologique, Lille, France speak:
Endovascular Challenges During TAAA Repair: Tips and Tricks
Prof. Haulon will also share his experience with Discovery. Stop by our booth to talk with him during the three breaks on Friday May 31 and Saturday June 1.
With GE Healthcare's newest Image Guided System, Discovery* IGS 730:
- Re-think the possibilities of high precision imagery with optimal in-room mobility.
- Re-invent the way you work.
- Do more - from complex interventional to surgical procedures - with exceptional dose efficiency.
Vision and motion with precision.
See how the Discovery IGS 730 can help you rediscover space and movement.
- In clinical use, the results of the application of dose reduction techniques will vary depending on the clinical task, patient size, anatomical location and clinical practice. The Interventional radiologist, assisted by a physicist as necessary has to determine the appropriate settings for each specific clinical task.
