Ultrasound System Tips from Trisonics!
Check out this tip from Trisonics!
Wed Oct 23 2013
CX50 Presets
It is important to back up your system specific presets during every pm inspection. This will include your imaging presets, Measurements and Calculations, system settings, network settings, options, and printer settings. Every system can be a little bit different in how to perform this backup. On the CX50 first you need to insert a blank CD into the CD drive on the side of the system. Next you press the system setup button on the top right of the qwerty keyboard. Once the setup menu opens select the Removable Media tab. At the top of the media tab select the CD drive. Below that select backup to media. Once everything is complete the system will let you know and you can eject the disk. It also a good idea to write down the IP address of the CX50 itself as this is the only important information that does not get backed up on the CD. As always, if you have any questions please contact Trisonics Ultrasound.
