GE Login Tips from Conquest Imaging
GE login tips from Conquest Imaging
Mon Jan 20 2014
GE Login Tips
When performing service on a GE ultrasound system that has a login / user name (any ultrasound system manufactured after 2002), be sure you are logged in as someone with administrative rights or you can log in as “admin”, password is either blank (empty field) or “ulsadm”. This will give you full access to the “Connectivity” tab functions as well as allow you more access to other software features. If you are unsure, tap the power button and choose “log off” and then hit “New patient” button and you will be prompted to log on.
Visit Conquest Imaging for all of your ultrasound needs!
