Tips from Conquest Imaging: Thermal issues with the GE Logiq and Vivid E9 systems
Wed Feb 05 2014
On the GE E9 series systems, debris that gets beyond the filter underneath the system accumulates on the fan tray below the system card cage and restricts air flow throughout the system. GE has addressed this design issue but it is still an area that needs to be cleaned on a regular basis. To access the fan tray, first remove the right side cosmetic cover, then remove the card cage cover. At the bottom of the card cage, the fan tray slides in horizontally. Remove the tray and clean the metal mesh and reinstall.
Visit Conquest Imaging for all of your ultrasound needs!
