PM tips for Medical Contrast Injectors!
Contrast media injector systems, though rarely touted as the most coveted piece of equipment in their department, play a vital role. They introduce observable substances at specific locations throughout the human body.
Tue Mar 04 2014
Contrast media injector systems, though rarely touted as the most coveted piece of equipment in their department, play a vital role. They introduce observable substances at specific locations throughout the human body. The average lifespan of these devices typically runs from 5 to 7 years; however, with regular preventative maintenance the life of a contrast media injector system can be extended.
Here are a few PM tips for Contrast injectors!
- Remove the injection/needleless cap from the catheter.
- Attach a 10 ml or larger syringe filled with sterile normal saline.
- Aspirate for adequate blood return and vigorously flush the catheter with the full 10 ml of sterile normal saline. Warning: Failure to ensure patency of the catheter prior to contrast injector studies may result in catheter failure.
- Detach syringe.
- Attach the contrast injector device to the catheter per manufacturer’s recommendations.
- Complete contrast injector study taking care not to exceed the flow rate limits. Warning: Exceeding the maximum flow rate of 5 ml/sec may result in catheter failure and/or catheter tip displacement.
- Disconnect the contrast injector device.
- Flush the catheter with 10 ml of sterile normal saline, using a 10 ml or larger syringe.
- Replace the injection/needleless cap on the catheter.
A couple more common tips:
- Handle leaks
- Invest in training
Be sure to visit Maull Biomedical or Injector Support and Service for all of your medical contrast injector needs!
