Trisonics Transducer Inspection Warning
Wed Mar 18 2015By Trisonics
It may sound routine but one of the most important things you can do, not only at PM time but any time you are near one of your ultrasound units, is check transducers for case damage or problems. The key with issues regarding transducer cases or cables is to have them checked and repaired immediately. The longer you wait, the less likely a repair can be successfully made or the more costly it will become. You can check all the transducers on a unit for damage or problems in the cable or case in just a minute or two. That minute can save you thousands of dollars.
Here is an example of a probe that had a small separation in the housing that became worse over time. From the outside it certainly looks like it needs help, but it does not look detrimental to the transducer (see figure 1). Figures 2 and 3 show what the internal effect was: the gel was forced inside the housing which caused a total failure of the transducer.
This went from being something simple to something detrimental, all due to time. Resolve these issues quickly for your best chance of saving the most in your repairs.
