Automated Testing with BC Group’s New CONMED PM Kit
CONMED PM Kit Provides the Tools for Automated Testing of CONMED System 2450 and 5000
Mon Nov 30 2015
The newest addition to the line of BC Biomedical products is the CONMED PM Kit, a complete set of accessories needed to safely perform preventative maintenance procedures. The CONMED PM Kit works with the ESU-2400 Series of electrosurgical unit analyzers to test the CONMED System 2450 and System 5000 electrosurgical unit generators. There are three pieces to the kit, including a port adapter, 3” jumper cable and the Monopolar Handpiece Simulator.
The port adapter that is included allows test leads with standard safety jacks to connect to the CONMED Systems 2450 and 5000 model generator’s combination monopolar output.
The Monopolar Handpiece Simulator is a new accessory for the ESU-2400 Series that allows technicians to safely and automatically perform leakage measurements. This works by triggering and measuring handpiece activated leakage measurements, without manually shorting the monopolar output terminals. One of the major benefits of automated testing with the Monopolar Handpiece Simulator is that the ESU-2400’s autosequences record measurements and produce a report once the sequence is complete. A technician doesn’t need to manually record each measurement and doesn’t have to worry about accidentally skipping a step.
BC Group designed the CONMED PM Kit specifically for use with the ESU-2400 Series. It is required if a user wants to properly perform PM autosequences on the CONMED System 2450 and 5000 using an ESU-2400 or ESU-2400H. The ESU-2400 Series PM autosequences are important for biomedical technicians because it provides faster and automated testing.
For more information about the CONMED PM Kit visit the online store at www.BCGroupStore.com or speak to a sales representative at (314) 638-3800.
