BC Group Announces the DA-2006-VL Has Received FDA 510(k) Clearance
Thu Jan 07 2016
The DA-2006-VL Variable Load Box is the newest accessory for the BC Biomedical line of defibrillator analyzers and has just received FDA 510(k) Clearance. It works in conjunction with the DA-2006 and DA-2006P Defibrillator Analyzer as an external load bank. If you already own a DA-2006 or DA-2006P you can update your software for free to be compatible with the DA-2006-VL. The DA-2006-VL is used when testing defibrillators to ensure the proper electrical current is delivered to the heart, per AAMI DF80 and IEC 60601-2-4 standards. Both AAMI and IEC require defibrillator analyzers to test a variety of impedances, to simulate a wide range of patients. With the DA-2006-VL, the DA-2006/P has test loads from 25-200 ohms and can be measured in 25 ohm increments.
With the DA-2006-VL’s advanced technology, it is automatically recognized by the DA-2006 Series, leaving no settings to change or configure. No other defibrillator analyzer load bank offers this feature.
The DA-2006-VL is only compatible with the BC Biomedical line of defibrillator analyzers. The DA-2006P combined with the DA-2006-VL offers a high quality analyzer at an unbeatable cost.
Click here to learn more about BC Group and their equipment.
