Announcing the QA-ES III Electrosurgical Analyzer for testing and ensuring the proper performance and safety of electrosurgical units
The Fluke Biomedical QA-ES III Electrosurgical Analyzer tests all critical electrosurgical unit (ESU) functions, including precision power, current, frequency, crest factor, and load resistance.
Tue Feb 16 2016
An electrosurgical unit (ESU) that does not function correctly can be hazardous, leading to ineffective cutting, cauterizing, or vessel sealing, burning a patient or physician, or even starting a fire. It is, therefore, important to verify the performance of electrosurgical units, and ensure they are operating as specified. The Fluke Biomedical QA-ES III Electrosurgical Analyzer tests all critical electrosurgical unit (ESU) functions, including precision power, current, frequency, crest factor, and load resistance.
"For over a decade, the QA-ES II Electrosurgical Analyzer has been a trusted tool for biomedical technicians," explains Eric Conley, General Manager for Fluke Biomedical. "Our new QA-ES III provides improved performance, wireless* functionality, and is ready out-of-the-box with no need for additional cables, leads or hardware. In addition, it is 5.5 pounds (2.5 kilograms) lighter than its predecessor, making it easier to carry from location to location."
The multi-purpose ports of the QA-ES III, coupled with its color-coded stacking leads, minimize the number of connections necessary to test and verify the performance and safety of ESUs. The QA-ES III also provides increased accuracy and range for measuring vessel sealing, contact quality monitor (CQM), high frequency (HF) leakage, and output power distribution in single or continuous mode.
"The QA-ES III has industry leading performance and specifications for power, current, peak-to-peak voltage, and crest factor, making it an ideal electrosurgical analyzer for today's modern high-power ESUs," explains Shirin Khanna, QA-ES III Senior Marketing Manager. "It can store up to 5,000 test records on-board that can be quickly and easily transferred to a PC via Bluetooth or USB."
The QA-ES III complies with the latest global industry standards for testing electrosurgical devices including ANSI/AAMI and IEC. It is easy to set-up and use with a large LCD screen and on-screen guides. It also features built-in automation for quick power distribution testing. An optional Ansur test automation plug-in standardizes work, shortens overall test time and reduces error by automating preventative maintenance procedures with customized test templates and reports.
*The QA-ES III will be offered worldwide. Wireless capabilities will initially be available in the U.S., Canada, and Europe (except Russia), and roll-out to other countries, starting in early March 2016.
This article was originally published on PR Newswire.
