How to Compare Equipment on MedWrench
In today's edition of the MedWrench blog I want to discuss how to compare equipment on MedWrench. I have seen an increase in the number of forum posts asking for information on the differences, pros/cons, etc. of equipment.
Thu Aug 25 2016
In today's edition of the MedWrench blog I want to discuss how to compare equipment on MedWrench. I have seen an increase in the number of forum posts asking for information on the differences, pros/cons, etc. of equipment. The purpose of today's blog is to provide a step by step guide on how to compare equipment on MedWrench. See below.
Step 1: Find the equipment/systems that you are wanting to compare. I am going to use two Ultrasound Systems for my comparison; therefore, I am going to access the Ultrasound System category by selecting “Imaging” in the “Browse Equipment Categories” menu located on the top left-hand side of the Homepage.
Step 2: From here simply select the Ultrasound category located on the left-hand side of the page under the “Browse Categories - Imaging” menu. Now, select “Ultrasound Systems” located again in the same place.
Step 3: From here you will simply need to click on the “Compare” checkbox located directly under the image of the listed equipment that you are looking to compare. I have selected the Acuson Sequoia and Aloka SSD-4000.
Note: you can further break down the listed equipment by selecting specific manufacturers that you want to compare again located on the left-hand side of the page listed under the “Browse Categories- Ultrasound- Ultrasound Systems” Menu.
Step 4: All you need to do now is scroll to the bottom of the page right below the very last piece of equipment listed. You will see a box that says “Compare Selected Instruments in Ultrasound Systems”. Click compare and you will be redirected to another page with a side by side comparison of the two units.
