Class 1 Recall: Baxter Corporation Recalls 50 mm 0.2 Micron Filter Due to the Potential for a Missing Filter Membrane and Possible Particulate Matter Contamination
Baxter Corp. is recalling the 50 mm 0.2 Micron Filter after receiving reports about the presence of particulate matter and the potential absence of filter membrane layers in the filter set.
Mon Oct 10 2016
Recalled Product:
- 50 mm 0.2 Micron Filter
- Product code: H93835
- Lot numbers: All unexpired lots
- Manufacturing dates: June 27, 2013 to June 27, 2016
- Distribution dates: August 12, 2013 to June 20, 2016
- Devices recalled in the U.S.: 130,100 units nationwide
Device Use
The 50 mm 0.2 Micron Filter is used in hospital pharmacy settings by pharmacy technicians to filter bacteria and other microscopic matter when preparing water-based solutions used for Intravenous (IV) fluid administration sets. The micron filter is a disposable device that attaches to the standard Baxter Pharmacy Pump tube, a pump that facilitates repeatable fluid drug dosage through the use of IV bags, syringes, infusers, and other drug administration containers.
Reason for Recall
Baxter Corp. is recalling the 50 mm 0.2 Micron Filter after receiving reports about the presence of particulate matter and the potential absence of filter membrane layers in the filter set (depicted in the image above). The absence of a filter membrane layer and/or the presence of particulate matter in the set may contaminate a solution. This could result in bloodstream infections that may cause fever, septic shock, multiple organ dysfunction, and other serious adverse health consequences including death.
Who May be Affected
- Patients receiving IV repeated medication dosage compounded in water-based solutions and filtered with the 50 mm 0.2 Micron Filter
- Pharmacy technicians and other health care professionals using the 50 mm 0.2 Micron Filter to prepare and filter medication dosages in water-based solutions
What to do:
On August 26, 2016, Baxter Corp. sent an “Urgent Product Recall” letter to affected customers and other third party distributors. The letter instructed customers to:
- locate and remove all affected product lots from their facilities
- contact Baxter Healthcare Center for Service to arrange for return and credit
- complete an enclosed Baxter customer reply form and return it to the company
- forward a copy of the communication to any third party customers
- conduct a consumer-level recall if they are dealers, wholesalers, or distributors
Contact Information
Customers can contact the Baxter Healthcare Center by phone at 888-229-0001 between the hours of 7 a.m. and 6 p.m. Central Time, Monday through Friday or by email at:corporate_product_complaints_round_lake@baxter.com
Date Recall Initiated:
August 24, 2016
