Storage Tubes with External Thread ensure Sample Integrity
Sample preservation and storage solutions designer Micronic released the innovative new 0.75ml and 1.40ml tubes with an external screw thread. The two tube sizes are the first in a range of new designs featuring an external thread.
Fri Dec 02 2016
Using externally threaded tubes for sample storage eliminates the possibility of the sample coming into contact with the screw thread, greatly reducing the chance of cross-contamination while improving sample integrity. Due to thick tube walls, the tube has a sturdy design and excellent properties for ultra-low temperature storage.
Externally threaded tubes allow for a higher (net) volume of material to be stored inside, which means that the sample tubes can hold more while occupying the same amount of storage space. The triple thread of the tubes gives an excellent closure and horizontal placement of the cap to ensure long-term sample preservation and storage. The screw cap also has a triple start thread for optimal sealing quality and is available in 6 different colors.
The code surface of the tubes with external thread features a raised edge, which protects the 2D code
against accidental scratches. Due to the unique injection molding technique used to manufacture the sample storage tubes, the black code surface with 2D Data-Matrix code cannot be separated from the transparent tube. The 2D codes also have a human-readable code for additional identification. The codes are permanently laser-etched into the tube bottom so that they can never wear or fall off.
Headquartered in the Netherlands, Micronic’s products are produced in a certified class-7 clean room environment at facilities in both the Netherlands and the United States. All of their labware equipment is also assembled in-house. The sample tubes are made using medical-approved polypropylene (CE-IVD) and are RNase/DNase and pyrogen free.
The tubes are available for purchase in bulk and in a Micronic ULT Rack, and are compatible with Micronic Univo Screw Cap Recappers and other automated systems. To order, contact sales@micronic.com or call your local Micronic sales office: http://www.micronic.com/contact.
Micronic is an independent organization with its headquarters located in Lelystad, the Netherlands. Our goal is to advance research by serving scientists in finding solutions that contribute to a higher quality of life. We develop and manufacture a range of Dutch-designed products to enhance the process of sample preservation and storage.
