SmartLung 2000 – The Test Lung Worth Buying
With the slider of this test lung, you can adjust various lung compliance values without an adapter. Multiple lung resistances can be simulated at the same time by simply turning the connector of the SmartLung 2000
Tue Mar 06 2018
The Imtmedical SmartLung 2000 is the smartest and most reliable tool for testing ventilators and anesthetic machines in accordance with IEC standards such as IEC 60601-2-12, IEC 60601-2-13 and EN 794-3.
With the slider of this test lung, you can adjust various lung compliance values without an adapter. Multiple lung resistances can be simulated at the same time by simply turning the connector of the SmartLung 2000. In addition, this test lung also makes it possible to apply volumes between 0 and 1000 mL and to simulate leaks in different stages.
The SmartLung2000 is available at an attractive price in the Imtmedical webstore.
