Richardson Healthcare helps you lower the cost of service with unmatched support and high value components.
The ALTA750" is a form, fit and function replacement for the Toshiba/Canon Medical Systems CXB-750D/4A CT tube, also known as the Varex Imaging MCS-7078 tube.* It is certified on OEM platforms from Toshiba Aquilion 4 through the PRIME (first generation).
Wed Jun 06 2018
The ALTA750, manufactured by Richardson Electronics, is a new CT tube specifically designed for use as a replacement tube for the Toshiba/Canon Medical Systems CXB-750D/4A* tube, also known as the Varex Imaging MCS-7078*. It is a new X-ray vacuum tube assembly reloaded into an OEM housing assembly.
ALTA750 tubes are sold in a bundle that includes a fully refurbished heat exchanger and a new high voltage cable. The ALTA750 has a prorated 12-month or 200,000 rotations limited warranty, whichever comes first.
For a limited time, all first-time customers of our ALTA750 will receive a complete satisfaction, money-back guarantee for 90 days after installation.
A note from IMES/Richardson Electronics:
Contact IMES!
