BC Biomedicals IPA-3400 Infusion Pump Analyzer Now Patented
The IPA-3400 Infusion Pump Analyzer is now patented under US Patent No. 10,100,828.
Thu Jan 03 2019
St. Charles, MO. - December 26, 2018 - The IPA-3400 Infusion Pump Analyzer is now patented under US Patent No. 10,100,828. Its cutting-edge, patented design uses a dual syringe stepper motor driven system that provides continuous monitoring of the fluid flow without the need to stop and perform intermittent drains like older technologies do. This provides a more realistic flow path for the Infusion Device inter test and therefore more accurate readings. Also, independent stepper motor control of the custom designed ceramic valving allows the system to run not only more quietly and more smoothly, but it also allows for a bidirectional powered fluid flow for use in the build-in cleaning cycle.
Some additional features include:
- Large 7" Color touch Screen
- Smooth Dual Syringe System that Eliminates Drain Cycle Inconsistencies
- Whisper Quiet Operation
- Auto Start
- Built in Data Collection
- Build in Auto Test Sequences
- Industrial Grade SS Pressure Sensor
- Performs ALL IEC 60601-2-24 Required Tests
- 10 uL to 1600 mL/Hr
- 4 USB posts and 4 AUX Ports
- Flash Drives, Barcode Scanners, Keyboard and Mouse Directly Supported
- PC COmpatible
- Configurable Pressure
To learn more about BC Group International, click here.
