The Joint Commission and the 100% PM Completion
Tony Cody, Technology Management Director at Banner Health, discusses his interpretation of 100% completion and how it can be accomplished.
Tue May 07 2019By Tony Cody
One of the relatively recent changes to The Joint Commission Accreditation standards that directly impacted the HTM community is the requirement for 100% PM completion.  Although this has been out for a couple of years, there is still some questions and confusion as to what constitutes 100% completion.  I wanted to give a personnel interpretation and a suggestion on how it can be accomplished.
When I first heard of this change, I panicked.  I thought it was absurd since there are almost always items in the hospital environment that are unable to be located.  Once I read several articles, asked questions directly to The Joint Commission, and consulted Mega-Gurus in the HTM field, I felt comfortable that 100% was achievable.  I learned “Completion” doesn’t mean performed.  If that is accepted, then what are acceptable actions that can still be counted as completed?  I came up with a short list:
  • If you look for an item repeatedly (and documented well)
  • If the item is unavailable to use (again multiples attempts and well documented)
  • If it fails the PM
  • Sent out to vendor but will be completed past PM due date
  • Scheduled with a vendor, but past PM due date
  • PM kit on backorder
The above listed is what I can argue as a considerable and valid attempt to perform a PM that can counted toward my completion percentage.  Please be ready to defend your methodology as they could have several questions directed to these elements of performances.  I can almost guarantee that it will not be acceptable if the “unable to locate” is only documented on the last day of the month or if you have a high percentage of PMs items not performed.  Hope this helps!
