MAQUET Releases Yuno OTN Advanced Surgical Table
MAQUET has released a new versatile surgical table that’s future proof, capable of handling patients up to 1,000 pounds. The unit is mobile and the company believes it can be used in all types of surgeries. The table features metal-free carbon-fiber structural components for radiotranslucency and easily adjustable components for quick and easy OR prep. Features from the product page:> State-of-the-art technology: The YUNO OTN’s intelligent modular design makes it ideal for all operations in orthopedics, traumatology and neurosurgery. Its precise settings, impressive stability and exceptional radiotranslucency help surgeons work as accurately as possible. Excellent radiotranslucency: because of the table’s intelligent design and carbon fiber components, you no longer need to re-position the patient during interventions for imaging, reducing procedure duration Innovative traction device: leg is raised and lowered in an arc – ensuring no unnecessary pressure is applied, and enhancing patient comfort Intelligent design down to the last detail: metal side rails can be easily detached for optimal radiotranslucency Innovative table column: The YUNO OTN’s unique column provides better access for surgeons and C-arms, and is height-adjustable for ergonomic workflows and optimal surgical site access Stability: The three-point base and slender yet sturdy central column and fully retractable wheels ensure exceptional stability, even when the table is set at its maximum height. So surgeons can work more comfortably and accurately – enhancing patient comfort Easy to assemble: the innovative “easy-click” modules mean re-configuring the table is simple, even with just a single staff member – while module recognition technology improves safety Autodrive function: the table is equipped with an electric motor and gently moves forward by simply pressing a button on the remote control – plus, staff can work more comfortably thanks to its ergonomic design Backlit remote control: OR staff can make precise adjustments at the touch of a button, even when lights are dimmed Table control: Four different remote controls available: corded hand control (backlit), IR hand control (backlit), foot switch, and override panel. Originally found on MedGadget View the Yuno OTN product page on MedWrench.
Wed Jul 27 2011
