What is a Sequential Compression Device?
Sequential compression devices are medical equipment units that help to improve circulatory function in people who have poor circulatory flow. These devices can be used in both hospitals and are approved for at home use. Continue reading to learn more about the Sequential Compression Device.
Thu Jul 18 2019By Soma Technology
The main goal of sequential compression devices is to recirculate the blood in a person’s body. Sometimes, people have circulatory issues from some diseases, or because they have limited mobility. If people are bedridden, the blood is unable to flow to each vein in the extremities. By limiting blood flow, the nutrients, oxygen, and water in the blood cannot be distributed to the necessary organs. When the blood cannot be distributed, the patient’s safety is at risk. Limited blood flow may cause a pulmonary embolism. A pulmonary embolism is a blood clot that can get lodged in the lungs, or into the heart. Deep vein thrombosis is when a blood clot is formed in a vein. A sequential compression device works by applying pressure to recirculate blood and allow blood to flow to all vital organs and extremities. The device is put on the extremity that has severe swelling. Air is pumped in the chamber and put on the swollen body part. After the pressure is applied, the blood is able to flow freely through the extremity. Sequential compression devices work to not only reflow blood but to prevent deep vein thrombosis or a pulmonary embolism.
Top 3 Sequential Compression Devices
There are a few different products that we sell refurbished. Below are three sequential compression devices, along with their features and specifications. Soma Technology only refurbishes the top products currently on the medical equipment market. After reading this article, you can ask any of our sales representatives about any questions, or to compare them!
Kendall SCD 700
The Kendall SCD 700 is a great sequential compression device. This device features smart compression controls to deliver compression to legs, feet, or both, and to aid in the prevention of venous thromboembolism, deep vein thrombosis, and pulmonary embolisms. This machine is designed to be portable for either in a hospital or at home use. Features on this device include a measure for venous refill time using Vascular Refill Detection technology and can customize compression cycles automatically. 100% of blood is moved every hour, and this device facilitates the tracking of patient therapy by detecting that the garments are actively working. This machine is very quiet, so as not to disturb the patient. A smooth, groove-less surface and slim profile make this device compatible for at home and hospital cleaning agents.  This machine is about 7 inches high, 8 inches wide, and has a depth of about 7.3 inches when not in use. This device weighs about 5 pounds and is portable for any place the patient can be in, either a chair, a bed, or somewhere else. The battery can run for between 6 and 8 hours and has a charge time of only 4 hours. The compression cycles for legs is 11 seconds; foot cuff cycle is 5 seconds.
Kendall SCD 9525
The Kendall SCD 9525 is a larger version of the SCD 700. The Kendall SCD Express system consists of a controller, non-disposable tubing, and single patient use leg garments. The compression sleeve has three bladders to deliver circumferential, sequential and gradient compression to ensure clearance of the deep veins without risking distal blood trapping. The SCD 9525 features delivery compression to the leg, foot, and both. This device can deliver 5-second 130mmHg foot compressions. This flexible and transportable design is ideal to be moved between patient rooms, or between rooms in a house for home use. An ergonomic handle and versatile bed mount can be used if you want to make this device immobile. The total weight is a little under 9 pounds, 6 inches tall, 7 inches wide, and has a depth of about 4.5 inches. The leg sleeve compression happens in 11 seconds, while the foot cuffs happen in about 5. The run time of the batter is 6 to 8 hours and has a charge time of 4 hours.
A-V Impulse
The Kendall A-V Impulse Foot Compression System is also made by the brand Covidien. Covidien is a trusted brand, for which, we refurbish so many of their products. This device, as well as the other two, prevents DVT and pulmonary embolisms. The ImPad rigid sole foot covers on the A-V Impulse, are designed with a hard sol that contains and directs the impulse to the bottom of the foot. This action mimics the natural hemodynamic effect of ambulation and has been clinically proven to reduce this incidence of VTE as well as post-operative swelling and pain utilizing the A-V Impulse. This machine is very safe. An automatic pressure adjustment assures delivery of the pre-set operating parameters regardless of any changes in patient position. There are low and high-pressure alarms to sound if there is too little or too much pressure applied to the garments. This machine weighs about 7.5 pounds and it easy to transport between patient rooms. An easy to read pressure display provides constant confirmation of the appropriate therapy.
Sequential Compression Device for Home Use
Sequential compression devices can be used at home. with proper training, a caretaker or a trusted family member can use this machine on a loved one. This allows patients to have treatment in the comfort of their home. Perhaps they may be bedridden or are unable to move due to mobility issues or stairs. This device relieves their circulatory pain, without having to go to a medical office.
The Refurbishing Process
Because Soma Technology is an ISO 13485 certified facility, we have a strenuous refurbishment process to make certain that all of our products are in great working condition. First, our purchasing team buys units from medical facilities. Once these medical units ship to our one of our five large warehouses, it is tested by highly trained biomedical engineers. Once necessary parts are replaced, the unit is sent to cosmetics for sanding, painting, and replacement of decals. After cosmetics, the unit is brought back to the biomedical engineers and tested again to make certain that the machine functions like new, and is up to original equipment manufacturer specifications. Finally, the machine is carefully packaged and shipped to your medical facility for immediate use.
Where to Buy a Sequential Compression Device
Soma Technology has a wide range of medical equipment options, so of course, we have sequential compression devices! These devices are refurbished back to OEM specifications. If you are not sure which of these devices is right for you, please talk to one of our sales directors. Our sales directors can help you pick out an option that is right for you, or right for your medical facility.
If You Don’t Want to Buy Just Yet
If you are not ready to purchase one, or you would like to test out the different models, we offer medical equipment rental options, and rent-to-own options as well. There are benefits to renting. Your facility can avoid acquisition and maintenance costs on your rented equipment. Equipment will be ensured to meet immediate needs. There is no downtime in operations due to repairs or preventative maintenance. In the unlikely event that a machine has an issue, we have a great service department.
Service Department
In the very rare and unlikely case that your machine encounters a problem either within our competitive warranty period or after the period is over, we have a great service department. We will assist you in getting a biomedical engineer to your facility, or arranging for technical support over the phone. We offer lifetime free technical phone support.
