FlowAnalyser PF-300 - the measuring and calibration device with extremely high precision
The high-end FlowAnalyser PF-300 is the ideal tool for engineers, health experts, and medical technicians. It can be used to check and calibrate all types of medical devices that generate pressure or flow.
Tue Oct 01 2019
The FlowAnalyser is an ideal calibration device for any anaesthetic machines or ventilators.Customizable measuring modes
The FlowAnalyser can bidirectionally measure flows, pressures, temperatures, moisture levels, and oxygen concentrations. The unique way of selecting the measuring mode for adult ventilation, pediatric ventilation, or high-frequency ventilation makes the FlowAnalyser an ideal calibration device for any anaesthetic machines or ventilator.
Industrial standard in several countries
Due to its unmatched precision, the FlowAnalyser PF-300 is considered an industry-standard in some countries in Central Europe as well as in Japan and China.
This ventilator tester is extremely easy to use and extremely high accurate. Thanks to its precision, it is regarded as an industry-standard in some Central European countries, as well as in Japan and China. At the push of a button, all readings can be saved directly on the device and output later for documentation purposes. The associated PC software FlowLab offers many options for graphical analysis and report creation.
- Flow accuracy ±1.75%
- Separate low-flow channel
- Bidirectional measurement
- Integratable MultiGasAnalyser
- Up to 17 gas standards and 27 ventilation parameters
- Display of curves and figures
- Various interfaces (USB, RS-232, external trigger input)
- Profile editor
To learn more about the FlowAnalyser PF-300, fill out the form below to receive a free White Paper. To learn more about IMT Analytics, click here.
