Announcing 4.4L Reservoir for the Belmont® Hyperthermia Pump
Belmont Instrument recently introduced a new 4.4L Large Volume Reservoir to supplement the Hyperthermia Pump. PRLog (Press Release) - Mar 17, 2011 - Belmont Instrument Corporation is continuing its dedication to innovative designs and hyperthermic
Wed Aug 31 2011By Belmont Instruments Corporation
PRLog (Press Release) - Mar 17, 2011 - Belmont Instrument Corporation is continuing its dedication to innovative designs and hyperthermic cancer therapies, as evidenced by the recent redesign of the reservoir based on feedback from pioneering physicians.
Belmont Instrument recently introduced a new 4.4L Large Volume Reservoir that will be part of the Straight and Bifurcated Hyperthermia Set disposable packages.
In addition to the larger fluid capacity, the reservoir now has all of the labeling for the ports already printed on the top of the reservoir; the vacuum relief valve is now pre-installed; the reservoir filter pore size is now 250 microns; and a medication port has been added to the top of the reservoir.
These improvements will make the set easier to install and use, and truly provide added value to the user. The Belmont® Hyperthermia Pump and disposable sets continue to provide advanced technology at a reasonable price
The Belmont® Hyperthermia Pump is a highly efficient, compact and easy-to-use system for the rapid circulation of warmed fluid used for hyperthermic lavage. The pump combines advanced microprocessor technology with an efficient mechanical system to provide a high speed, simple and safe system for the delivery of hyperthermic therapy.
Belmont Instrument Corporation has developed sophisticated and reliable devices in fluid management and cardiac assist since its founding in 1980. The Belmont® Rapid Infuser is used to save lives in more than forty thousand procedures per year in hospitals throughout the world.
Visit Belmont Instrument Corporation for more information.
Share:
