RPI Is Your Best Source for Sterilizer Calibration and Diagnostic Kits!
Whether you need to calibrate a MidmarkRitter autoclave, a Tuttnauer automatic auto clave, or a Sterrad H2O2 sterilization system, RPI has the perfect Calibration and Diagnostic Kit for your needs!
Tue Jun 01 2021
FIELD SERVICE CALIBRATION SMART® KIT
RPI Part #MIK074
When calibrating and checking the PC Board controls for pressure and temperature, this Kit contains all of the essential tools needed including a Test Pressure Gauge, Max Register Thermometer, Trip Pot Adjustment Tool, and more. Click below for specific Midmark models that can use this kit.
DIAGNOSTIC SMART® KIT
RPI Part #TUK108
This essential diagnostic kit was designed for calibrating and verifying the Pressure Transducer, and Temperature Sensor at install. In addition, when troubleshooting and testing all test points from the AJUNC or ANL boards, this the Kit to use. Click below for specific Tuttnauer models that can use this Kit.
VACUUM TEST GAUGE KIT
RPI Part #SDK112
This Vacuum Test Gauge Kit includes the essential tools used for calibrating the pressure transducers, measuring the vacuum leak rate, and verifying the vacuum pumps used in Sterrad Hydrogen Peroxide Sterilizers. Click below for specific Sterrad models that can use this Kit.
