Ask The Expert
Early Warning Signs
MedWrench recently spoke with Ted Lucidi, CBET from Innovatus Imaging, about how to ensure your ultrasound probes are in top condition.
Wed Dec 01 2021By Innovatus Imaging
Newbies to supporting diagnostic ultrasound have often asked, “How should we approach probes as part of the PMs on our systems?” Back in September, Innovatus participated in Ask the Expert and presented “5-Rules for Testing Ultrasound Image Quality”. Image quality is actually the culmination of all of the research and technology within and surrounding the probe itself. Whether your ultrasound departments pursue accreditation through the ACR, AIUM, IAC, or not at all, there are other criteria besides image quality testing that are important to ensure that your probes are in top condition. The answer to the question above, is a thorough visual and physical inspection.
What is Preventive Maintenance?
A simple web search on the term preventive maintenance (PM) results in 171 million results in 0.5 seconds but its definition and how its practice is implemented differs based on many criteria. No doubt, it’s not necessary to take MedWrench readers back to HTM 101. Let’s define a PM as routine, scheduled activities designed to minimize unplanned downtime and expensive costs associated with unanticipated failures. PMs on ultrasound systems can vary greatly depending on who is performing the PM and the type of PM program established (Traditional or Alternative Equipment Maintenance Plan). What’s performed as part of the PM can differ greatly as well, and some facilities have generalized PMs across all makes/models of scanners.
According to several GE service manuals, air filter cleaning and cleaning of the scanner is the responsibility of end-users and should occur monthly, and probes are to be visually inspected prior to each use. For those that have supported this modality, we know that these tasks typically don’t occur, at least by the sonographers.
What does an OEM-level PM consist of?
Depending upon the OEM and contractual obligations, a PM may only be performed once every year. Traditionally, the overall system is cleaned, visually inspected, damaged mechanical parts are replaced, and diagnostics are run. General image quality checks are performed as well as electrical safety. If probes are damaged, or their safety or function is in question, it is suggested they be replaced. If the system is under service contract, the probes may be replaced without additional cost. If not supported under contract, replacement probes are an added expense.
Are probes not considered part of the system?
Most facilities categorize ultrasound probes as accessory devices, when they are in fact separate Class 2 medical devices. The definition of and average cost of acquiring or replacing a single ultrasound probe meets most criteria for capital equipment. Yet seldom are ultrasound probes assigned an asset tag or included in a PM program. They’re usually just associated with the scanner and included as part of its PM.
Some things to consider…Probes often migrate between scanners or scan rooms as needed. A reality is that a good portion of a facility’s probes may seldom or NOT be visualized as part of the PM of a scanner.
Fact Check: Ultrasound probes are some of the highest failure items associated with diagnostic ultrasound, and they are one of the largest contributors of service spend
Why is that?
Several reasons exist for this. Remember, most sonographers do not perform daily or even frequent visual inspections to their probes. They also may never have been informed on what to inspect. Remember, probes may not be inventoried, not be included in a formal PM program, or missed when inspecting the scanner to which they may be associated. Finally, the main reason that probes are the most expensive part of supporting ultrasound is that many users wait until there is a significant image quality or performance problem before arranging for service.
Just like a car, a probe will exhibit certain characteristics prior to a major failure. Your car’s brakes may begin to chirp when the brake pads are significantly worn. The tire treads have wear indicators that inform when they should be replaced. Late model cars tell us when our oil needs to be changed. Our cars are equipped with all types of sensors that provide early warning signs to help us avoid catastrophic failures. Believe it or not, ultrasound probes provide early warning signs as well. They’re just not as obvious as a blinking red light on our dashboard.
What are some of the early warning signs?
After repairing well over 170,000 probes as well as being an FDA registered manufacturer of ultrasound probes, our teams understand the points of wear on probes and the signs that indicate a larger failure may be imminent. For instance, continued exposure to harsh chemicals used for cleaning and disinfection WILL 1) cause degradation of the seal that surrounds the acoustic lens, 2) WILL cause the adhesive bonds that join the various sections of the probe housings to deteriorate and begin to separate, and 3) WILL affect the flexibility of the strain relief. Yes, even chemicals approved for use on these devices WILL affect long-term performance. The use of improper chemicals or approved chemicals used improperly WILL accelerate the wear.
Once the seams and seals deteriorate, the probe is open to external contaminants such as gels, bio-burden, and chemical disinfectants. Biological contaminants allow for potential cross-contamination and chemicals and gels can rapidly corrode the internal electronics. The strain relief is designed to protect the cable jacket and internal wiring from wear as a result of hundreds of thousands of repeated flexes. Once a strain relief begins to separate, begins to stiffen, or begins to deteriorate, its protective features are diminished. Don’t these symptoms seem to speak to preventive maintenance?
Fact Check: The cost to address seams, seals, and strain reliefs typically only costs as little as a few hundred dollars. The cost to restore image quality and functional efficacy can cost thousands and may not even be possible on some probe models. Based on over 15 years of data, anywhere from 20-45% of all probes currently in-use, right now, require some level of maintenance.
So where do you begin?
Start by inventorying your probes and adding them to a PM schedule. Periodically inspect each probe for open seals, separated seams, and damaged strain reliefs. Better yet, partner with your sonographers. Attend one of their department meetings. Discuss the realities and costs associated with probe failures, teach them what to look for, and encourage them to inform you of any concerns.
Where can you find resources?
Innovatus Imaging publishes several visual inspection guides that can be used educationally and even posted in each exam room to keep the concept top-of-mind. The guide can be downloaded from the resources section of our website and printed, or we can send high quality hard copies to your facility. Our team is also available to hold on-site and virtual trainings. Go to https://www.innovatusimaging.com/resources/
If you don’t schedule time for preventive maintenance, your device will schedule it for you…and usually at the most inopportune time.
Author: Ted Lucidi, CBET: Clinical, Technical, and Commercialization Specialist
ted.lucidi@innovatusimaging.com
