Micronic, leader in innovative sample storage and automation solutions launches the Micronic Tube Reader DT510.
The Micronic DT510 is high-speed storage tube code reading at its best. Attractively designed to enhance your lab space the Micronic DT510 is truly versatile - it reads 1D rack barcodes, 1D barcoded tubes and 2D Data-Matrix coded tubes (in 96-, 48- and 24-well formats) all in less than a second.
Wed Dec 08 2021
The Micronic Tube Reader DT510 is a plug-and-play reader that requires no software installation and is very easy to use. The read data can be sent to multiple applications due to its proprietary keyboard wedge functionality. Using the keyboard wedge high-end decoding engine ensures that the decoding process is highly reliable thereby producing unmatched data integrity. Designed to increase your productivity - scanning and decoding a tube takes less than one second. An integral light assists easy and unambiguous sample identification.
The extremely compact (90mm x 80mm x 95.4mm), robust and stable design of the Micronic DT510 combined with affordable pricing makes it an ideal choice for any laboratory / storage facility requiring high integrity scanning of 1D or 2D Data-Matrix coded storage tubes. The Micronic DT510 gives a sound confirmation when the code is accurately read. The Micronic Tube Reader DT510 comes with a 5-year warranty to help minimise its cost of ownership.
The Micronic Tube Reader DT510 is available as single unit.
To learn more click HERE.
