Canon RadPro Digital
The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Canon RadPro & RadPro Flex Plus portable systems.
Start Date: Monday, Mar 27 2023
End Date: Friday, Mar 31 2023
Overview
Portable X-ray units are found in most radiological/diagnostic imaging departments. They are typically exposed to a higher abuse level due to elevator openings, tight room entrances, limited patient access, and lack of space for maneuverability. This constant abuse will cause premature mechanical failure if not properly identified and corrected early. The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Canon RadPro & RadPro Flex Plus portable systems. Each sub-system of the mechanical unit and the Sedecal generator is thoroughly analyzed.
Models Covered
This course will cover the following models:
- RadPro
- RadPro Flex Plus
Prerequisites
To attend this course, the service professional must have a good understanding of the principles gained through attending Phase 2, or 4 years equivalent experience. The service professional must also possess a good mechanical aptitude.
Objectives
- Evaluate overall system performance
- Troubleshoot mechanical and electronic problems on all components of the unit
- Perform a complete and thorough preventive maintenance inspection on each portable unit
- Follow circuit operations of system detail block diagrams
- Calibrate the digital detector
- Canon CXDI
