Servicing the Philips Family Ultrasound iU22/iE33 (2.5 Days)
The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Ultrasound system. Each sub-system of the mechanical unit and the generator are thoroughly analyzed.
Start Date: Wednesday, Mar 22 2023
End Date: Friday, Mar 24 2023
Overview
Ultrasound systems are found in most radiological/diagnostic imaging departments. They are typically exposed to a higher abuse level due to elevator openings, tight room entrances, limited patient access, and lack of space for maneuverability. This constant abuse will cause premature mechanical failure if not properly identified and corrected early. The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Ultrasound system. Each sub-system of the mechanical unit and the generator are thoroughly analyzed.
Prerequisites
To attend this course, the service professional must have a good understanding of the principles of Ultrasound or 3 years equivalent experience.
Objectives
- Understand theory of operation of the Philips Ultrasound Family
- Demonstrate the operations
- Evaluate overall system performance
- Troubleshoot mechanical and electronic problems on all components of the unit
- Perform a complete and thorough preventive maintenance inspection on each unit
- Follow circuit operations of system detail block diagrams
- Identify signal flow and label system block diagrams
- Understand image quality as it pertains to ultrasound
- Identify probes and their uses
- Perform networking and DICOM setup
