Introducing the IPA-3100
BC Group is excited to announce the upcoming release of its latest intuitive and easy-to-use single pump Infusion Pump Analyzer!
Mon Feb 27 2023
BC Group anticipates the upcoming release of its latest intuitive and easy-to-use single pump Infusion Pump Analyzer at the end of this month. The IPA-3100 is the most compact, feature dense single channel analyzer on the market. It is a high accuracy system that incorporates full touch screen control.
The BC Group patented design of this new BC Biomedical analyzer uses a dual syringe stepper motor driven system. This provides continuous monitoring of the fluid flow without the need to stop and perform intermittent drains. It also provides a more realistic flow path for the Infusion Device under test and therefore more accurate readings.
The IPA-3100 has configurable test parameters which allows for specific test routines specified by various manufacturers. Tests can be stored manually or automatically up to 250 different records. These test records can be downloaded to a computer to then create reports that can be printed.
The IPA-3100 is Bluetooth capable to allow for wireless testing and control. With the use of myBC Mobile or BC Flow, multiple test configurations can be stored for quick testing. Records of each test can be created and then saved for later viewing and analysis. Reports can also be generated from test records for in-depth analysis and/or traceability.
Once the IPA-3100 is released, it will be available for purchase on BCGroupStore.com
