FDA Alerts
Fresenius Kabi Recalls Ivenix Large Volume Pump
Mon Jan 22 2024By FDA
Fresenius Kabi is recalling the Ivenix Large Volume Pump (LVP), a primary component of the Ivenix Infusion System, because some units have mechanical issues with the Fluid Valve Pins, located inside the pump’s internal housing, causing the pins to not move properly.
READ MORE »
