FDA Alerts
Early Alert: Issue with Certain Infusion Pumps from Fresenius Kabi USA
Tue Dec 17 2024By FDA
The FDA is aware that Fresenius Kabi USA has issued a letter to affected health care providers indicating a subset of Ivenix large-volume pumps (model LVP-0004; UDI 00811505030320) are to be removed from use for repair.
Fresenius Kabi reports that a subset of pneumatic valves installed in some Ivenix LVPs have an increased chance of issuing a non-recoverable pump problem alarm. All devices with the affected valves should be removed from use, if possible, to be evaluated and returned to Fresenius Kabi’s facility for repair.
  • If the pneumatic valve fails, a Pump Problem alarm will be raised.
  • If this failure occurs during LVP setup this could potentially delay therapy.
  • If this failure occurs during an active infusion and flow is interrupted, this could lead to an
    underdose.
  • Delay or interruption of a life-sustaining infusion may result in permanent disability or death.
The pump problem alarms are working as intended and will arise indicating when to act if the malfunction occurs.
Read More Here
