Continuing Education
Servicing the Philips Family Ultrasound Epiq 5/7 (2.5 Day)
To attend this course, the service professional must have a good understanding of the principles of Ultrasound or 3 years equivalent experience.
By RSTI
Start Date: Mon Jul 13 2026
End Date: Wed Jul 15 2026
Overview
Ultrasound systems are found in most radiological/diagnostic imaging departments. They are typically exposed to a higher abuse level due to elevator openings, tight room entrances, limited patient access, and lack of space for maneuverability. This constant abuse will cause premature mechanical failure if not properly identified and corrected early. The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Ultrasound system. Each sub-system of the mechanical unit and the generator are thoroughly analyzed.
Prerequisites
Objectives
  • Understand theory of operation of the Philips Ultrasound Family
  • Demonstrate the operations
  • Troubleshoot mechanical and electronic problems on all components of the unit
  • Perform a complete and thorough preventive maintenance inspection on each unit
  • Identify signal flow and label system block diagrams
  • Understand image quality as it pertains to ultrasound
  • Identify probes and their uses
  • Perform networking and DICOM setup
Register Here
