Mobilize is Changing the Preventive Maintenance Game
If you're tired of juggling paperwork, manually logging test results, and chasing down PM records after the fact, you're not alone. Biomedical engineers have been on the search for a better way to manage preventive maintenance, one that actually fits the reality of the job.
Tue Mar 03 2026
That was Pronk Technologies’ goal in developing Mobilize: a complete wireless solution that puts PM testing, data capture, and documentation in the palm of your hand. Literally. No stacks of manuals to lug around.
No two biomed technicians are the same. Whether you’re testing in-house or working on-the-go, Mobilize syncs your test equipment to your iPhone or iPad, giving you full control over electrical safety testing, vital signs simulations, IV pump analysis, and more.
What Exactly Is Mobilize?
We understand the barriers between equipment setup, testing, and reporting can be cumbersome. Mobilize breaks down those walls and clears a pathway to quick, accurate preventive maintenance.
The app works seamlessly with compatible Pronk solutions including the Safe-T Sim Electrical Safety Analyzer, SimCube NIBP Simulator, OxSim Flex SpO2 Simulator, FlowTrax IV Pump Analyzer, and Pressure MAX Digital Pressure Meter. It also connects with a variety of third-party testing equipment commonly used by biomeds everywhere; Current partners include TSI and Datrend, with additional integrations on the way.
It’s designed to excel in three key areas:
- Wireless control over all your test equipment from a single interface
- Automatically capture test results in real time — say goodbye to pens and paper
- Generate complete, ready-to-sync service reports on the spot
And best of all, you can start improving your workflow for free. No monthly fees. No licensing hurdles. Just install it and start testing.
Mobilizing the Biomed Approach
The reality of biomedical work is this: you’re constantly moving — between departments, between facilities, between devices. Accuracy and speed is the name of the game; lacking in either area causes a ripple effect of complications.
Mobilize was built for that reality. It’s not a gimmick. It’s a genuine productivity tool that reduces the administrative burden of PM work so you can focus on what actually matters: keeping medical devices safe and operational.
There’s no barrier to getting started. Download the app, connect your test equipment via Bluetooth, and see for yourself how much time you get back in a single maintenance test, let alone in an entire workday.
The Features That Actually Make a Difference
Mobilize isn’t just about wireless control. It’s about eliminating the friction points that slow you down and introduce errors. Here’s what that looks like in practice:
- Built-in barcode scanner: Scan the device ID directly into your test record — no manual entry, no typos.
- Capture photos: Snap pictures of the device under test and attach them directly to the service record. “It was scuffed when I got here.”
- Work offline, sync later: The app stores up to 1,000 detailed test records locally. You can work in the field all day and sync your data when you’re back online.
- Wireless PM sticker printing: Connect a Brother P-Touch Cube Plus or XP Bluetooth printers & print custom PM stickers on the go — complete with next inspection due date.
Everything you do in the app is captured in a complete electronic report. When you’re done, you can transfer individual records or batch exports for easy filing and compliance documentation.
Use Two Fully Capable Modes Out the Gate
Mobilize gives you two powerful testing modes at no cost.
Safety Only Mode
Built for quick electrical safety testing.
If all you need to do is verify that a device is electrically safe, whether it’s incoming inspection or routine spot-checking, Safety Only Mode gets you in and out fast.
- Run electrical safety sequences directly from your mobile device
- Test results are captured automatically, no manual entry needed
Ideal for departments that need to verify safety compliance quickly without the overhead of full PM procedures.
Device Type Mode
This is where Mobilize really shines for full preventive maintenance work.
Device Type Mode lets you build and save custom test protocols based on the type of medical device you’re servicing, patient monitors, defibrillators, ventilators, infusion pumps, electrosurgical units, and more.
- Create custom PM protocols and save them in the app’s library for repeated use
- Run electrical safety testing and vital signs simulations in one seamless workflow
- Snap test results into the record with a single tap, or mark pass/fail as you go
One More Thing: Meet Pronk CheckMate
Mobilize now supports CheckMate, a new testing mode that takes automation to the next level. CheckMate uses manufacturer-based checklists to walk you through PM procedures step by step. Think of it as having the OEM service manual built directly into your workflow. Step 1, Step 2, Step 3, with each action prompted, each measurement captured, and every result logged automatically.
It’s designed to:
- Eliminate guesswork
- Reduce training time for new techs
- Ensure consistency across your entire PM program
Instead of building custom protocols from scratch, you follow validated procedures aligned with testing guidance. That means tighter compliance, fewer missed steps, and stronger documentation across your department.
Native CMMS Workflow Support
Mobilize is designed to work naturally alongside your CMMS, not around it.
All testing tools and workflows can be accessed directly from CMMS work orders, reducing back-and-forth between systems and keeping everything tied to the job you’re already working on. Mobilize handles the testing experience, while your CMMS remains the system of record.
Support for additional CMMS platforms can be added as needed to fit client workflows.
Ready to see Mobilize in action?
Download the free Mobilize app or visit Pronk Technologies to learn more about compatible test equipment and CMMS integration options.
