Continuing Education
Fuji DR Go & Go Plus
The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Fuji FDR Go & FDR Go Plus Portable.
By RSTI
Start Date: Mon Nov 09 2026
End Date: Fri Nov 13 2026
Overview
Portable X-ray units are found in most radiological/diagnostic imaging departments. They are typically exposed to a higher abuse level due to elevator openings, tight room entrances, limited patient access, and lack of space for maneuverability. This constant abuse will cause premature mechanical failure if not properly identified and  corrected early. The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Fuji FDR Go & FDR Go Plus Portable. Each subsystem of the mechanical unit and the generator is thoroughly analyzed.
Models Covered
This course will cover the following models:
Fuji FDR Go (MUX-200)
Fuji FDR Go Plus (MUX-300)
Prerequisites
To attend this course, the service professional must have a good understanding of the principles gained through attending Phase II, or four years equivalent experience. The service professional must also possess a good mechanical aptitude.
Objectives
  • Troubleshoot mechanical and electronic problems on all components of the unit
  • Perform a complete and thorough preventive maintenance inspection on each portable unit
  • Calibrate the digital detector
Register Here
