Patient Monitor Series Designed for ASCs, Rural Facilities
Wed Jul 08 2026
Philips now offers a full monitoring solution with innovations that support the needs of rural hospitals, ambulatory surgery centers (ASCs) and other key segments of the U.S. healthcare industry.
The solution, the IntelliVue Patient Monitor 6000 Series, provides an accessible entry point to enterprise-grade capabilities and trusted Philips patient monitors at an affordable price. The PM 6000 Series’ flexible approach to measurements – core parameters built in, plus innovative ways to quickly expand – gives clinicians the ability to easily monitor patients across acuity levels.
Expanded connectivity options, meanwhile, help organizations choose the scalable deployment approach that best fits their needs. Organizations can use the PM 6000 Series for standalone monitoring, directly connect to the EMR through HL7 outbound* or integrate at an enterprise-wide level through the Philips patient monitoring ecosystem. When integrating into an existing Philips deployment, the PM 6000 Series can use the same supplies as the well-established line of IntelliVue MX monitors.
Such flexibility with measurements and deployment is particularly critical for rural hospitals and ASCs, which must balance budget pressures, staffing shortages and growing patient complexity, while also needing to modernize workflows and prepare for future connectivity needs.
The PM 6000 Series can help streamline operations with its design, too. Each of the three models has core measurements built in, representing a different approach from the existing line of MX monitors. The self-contained, one-piece construction of the PM 6000 Series, alongside standardized configurations, can help simplify deployment, training and maintenance. The sleek design can also support cleaning and infection control.
Simplified does not mean compromised performance and flexibility, however. The PM 6000 Series uses the same IntelliVue software as MX monitors for fast clinical adoption, full clinical decision support and the latest cybersecurity measures. Flexibility, meanwhile, comes in part from two innovations intended to support the next-generation monitoring portfolio at Philips.
Now debutinginthe PM 6000 Seriessolution, theIntelliVueMeasurement Rack 6000 uses IntelliVue modules to help clinicians quickly expand monitoring capabilitiesbeyond built-in measurements, meetingtimelypatient needs. The rack also helps organizations adaptthe monitor for different care areas andacuity levelswithout replacing existing equipment,to supportevolving clinical and operational needs.
Expanding that flexibility further,thePM6000 Seriesfeaturesnew Flexible Link technology, the firstPhilipsmonitors to do so. These connectors allow organizations to easily add measurements after the point of sale. Each model features two Flexible Link connectors, providing plug-and-play expansion through a new generation of modules that can move easily between compatible monitors. Clinicians can quickly add capabilities in response to changing patient needs, while organizations gain a more scalable, streamlined path to future monitoring innovations.
“Every day, clinicians look to deliver the best possible care but face inefficiencies and challenges beyond their control,” said Ajay Parkhe, Business Leader, Hospital Patient Monitoring at Philips. “The PM 6000 Series helps ease pressure on healthcare organizations with flexible, high-quality patient monitoring in an affordable, scalable solution.”
* When running IntelliVue software T.0 or above.
