Servicing the Shimadzu MobileDart Evolution Family (MobileDaRt, EFX, MX7)
The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Shimadzu MobileDart Evolution Portable Family.
Start Date: Mon Oct 05 2026
End Date: Fri Oct 09 2026
Overview
Portable X-ray units are found in most radiological/diagnostic imaging departments. They are typically exposed to a higher abuse level due to elevator openings, tight room entrances, limited patient access, and lack of space for maneuverability. This constant abuse will cause premature mechanical failure if not properly identified and corrected early. The trained service professional will be taught the skills necessary for mechanical, electromechanical, and electronic maintenance of the Shimadzu MobileDart Evolution Portable Family. Each sub-system of the mechanical unit and the generator is thoroughly analyzed.
Models Covered
This course will cover the following MobileArt & MobileDart models:
- MobileDart Evolution (MUX200)
- MobileDart Evolution (MUX200D)
- NOTE: Pending equipment availability at the time of training, the following systems may also be available during the training:
- MobileArt (MUX100)
- MobileDart (MUX100D)
Prerequisites
To attend this course, the service professional must have a good understanding of the principles gained through attending Phase II, or four years equivalent experience. The service professional must also possess a good mechanical aptitude.
Objectives
- Evaluate overall system performance
- Troubleshoot mechanical and electronic problems on all components of the unit
- Perform a complete and thorough preventive maintenance inspection on each portable unit
- Follow circuit operations of system detail block diagrams
- Calibrate the digital detector (MUX200D)
- Canon
- Konica
