HTM and Infection Control: The EquipmentDriven Side of Hospital Hygiene
Mon Oct 19 2026
Infection control is often portrayed as the domain of nurses, environmental services, and sterile processing departments. They are the visible guardians of hospital hygiene—the ones who wipe surfaces, manage isolation protocols, and enforce handwashing compliance. But after twenty years in the biomedical equipment field, I can tell you that infection control has another side, one that is quieter, more technical, and just as essential: the equipment driven side managed by HTM professionals.
If you ask most people in healthcare who is responsible for infection control, very few will mention the BMET. Yet every day, technicians make decisions that directly influence infection risk. Every sterilizer we validate, every washer disinfector we verify, every endoscope reprocessing cycle we support, even the route we walk around the hospital impacts whether equipment is truly safe for patient use. Infection control is not just a clinical responsibility; it is a technical one, and HTM sits at the center of it.
Let’s start with sterilizers. These machines are the backbone of surgical safety. When a sterilizer fails, the consequences ripple through the entire hospital. Surgeries get delayed, instruments get diverted, and sterile processing goes into crisis mode. But the deeper risk is invisible: improperly sterilized instruments can introduce infections that may not be traced back to the source until days later. BMETs are the ones who ensure sterilizers reach the correct temperatures, maintain pressure, and complete cycles without deviation. We verify that sensors are accurate, chambers are sealed, and steam quality meets standards. A technician who cuts corners on sterilizer validation isn’t just risking equipment failure—they’re risking patient lives.
Washer disinfectors are another critical piece of the infection control puzzle. These machines are often misunderstood. Many clinicians assume that if a washer runs, it’s working. But BMETs know better. A washer disinfector can appear functional while failing to reach proper temperatures, missing chemical dosing, or running incomplete cycles. These failures don’t produce alarms; they produce contaminated instruments. BME professionals ensure that every cycle meets the manufacturer’s specifications, that spray arms rotate freely, and that chemical pumps deliver the correct concentrations. We catch the subtle issues that sterile processing staff may never see.
Endoscope reprocessing is perhaps the most complex and high risk area of infection control. Endoscopes are notoriously difficult to clean, and improper reprocessing has led to outbreaks in hospitals around the world. BMETs play a critical role here not only in maintaining automated endoscope reprocessors, but in verifying that leak tests, disinfection cycles, and rinse processes are functioning correctly. We ensure that filters are replaced, pumps are calibrated, and cycle logs are accurate. When an AER fails, the risk is immediate and severe. BME professionals are often the last line of defense between a contaminated scope and a vulnerable patient.
Environmental monitoring equipment also falls under HTM’s influence. Temperature and humidity sensors, incubators, isolation room pressure monitors, and air filtration systems all contribute to infection control. BMETs ensure these devices are calibrated and functioning properly. A negative pressure isolation room that isn’t truly negative can expose staff and patients to airborne pathogens. A refrigerator storing vaccines or medications that drifts out of range can compromise sterility. These are not theoretical risks—they are daily realities in healthcare, and HTM professionals manage them quietly and consistently.
One of the most overlooked aspects of infection control is equipment design and selection. BMETs often participate in capital planning, and our input matters. Some devices are easier to clean than others. Some have specific cleaning guidelines, others have fewer crevices, smoother surfaces, or better cable management. Some are designed with infection control in mind, while others are not. When Biomed is involved in purchasing decisions, hospitals avoid equipment that creates unnecessary hygiene challenges. When Biomed is excluded, they often learn the hard way.
Another critical area is user induced contamination. BMETs routinely encounter devices covered in residue, fluids, or biological material. We see the aftermath of rushed workflows, improper cleaning, and equipment misuse. Part of our role is educating clinicians on proper cleaning procedures, safe handling, and device limitations. Infection control is not just about machines—it’s about behavior. BMETs are uniquely positioned to influence that behavior because we see the consequences firsthand. Even when working on equipment in the BME shop we should always best practice by cleaning the unit prior to and post maintenance performed.
The HTM profession also plays a role in outbreak response. When a hospital faces a cluster of infections, BMETs are often called to inspect equipment, verify sterilization logs, and ensure reprocessing machines are functioning correctly. We help trace the root cause, identify failures, and restore safe operation. During crises, our technical expertise becomes a critical part of the infection control team.
Despite all this, HTM’s role in infection control is rarely acknowledged. It’s not glamorous work. It doesn’t make headlines. But it is foundational to patient safety. Every validated sterilizer, every calibrated washer disinfector, every properly functioning AER is a victory that prevents infections before they happen. They are quiet successes, invisible to patients but essential to their wellbeing.
As an educator, I believe infection control must be taught as a core Biomed competency. Students need to understand that their work directly influences hygiene and safety. They must learn the science behind sterilization, the mechanics of reprocessing, and the risks of equipment drift. They must understand that infection control is not just a clinical protocol but rather it is a technical responsibility that demands precision, diligence, and accountability by all hospital employees both nurses and biomeds alike.
BME professionals are not just technicians; we are guardians of safety. Infection control is not someone else’s job. It is ours. And when we do it well, patients will never know the danger they avoided.
