Preventative Maintenance Tips for CT Scanners
CT scanners are used on just about every area of the body to identify medical issues. With such an important and expensive piece of equipment, medical facilities often employ a comprehensive quality control program.
Thu Jun 07 2012
CT scanners use to be limited to diagnostic images of the brain. Now, CT scans are used on just about every area of the body to identify medical issues. With such an important and expensive piece of equipment, medical facilities often employ a comprehensive quality control program.
The preventative maintenance routine for your CT Scanner should include an annual investigation to preempt any possible defect, and to identify signs of wear. It is encouraged to also perform monthly checks for calibration, radiation dosages and image resolution and accuracy.
To stay up to date on news and products in this category, add the CT Scanner Community to your My Bench using these icons ,,.
If you need parts, service or refurbished equipment regarding CT Scanners, check out our sponsors for this category: Medical Imaging Technologies, C&G Technologies and Adam Imaging Parts.
Post a comment to share your preventative maintenance tips...
