Hillrom - VersaCare
by Hillrom
The VersaCare bed is easier to use with new intuitive controls and digital head of bed display. And the Boost® feature to help prevent back injuries.
0RepliesMon Jul 28 2025 | HiLow function lockout error I thought I'd share my experience with the lockout issue that was plaguing a bed. It would constantly lock out all controls with a lit-up wrench light. Unlocking would make the bed functional for a couple seconds but would lock out again. According to the manual it was the logic board that was faulty, which we ended up replacing but did not solve the issue. It was determined with support to be most likely that the 2 actuators were faulty. Being a school with limited budget, I decided to do further troubleshooting before purchasing 2 new complete units. I found that the feedback voltage coming from the potentiometer in the actuator would become erratic and cause the bed to lock up. I disassembled the 2 actuator heads, removed the potentiometer component and carefully took apart and cleaned the contacts and board. After reassembly the bed functions perfectly normal. Not sure if this will help anyone as it is a lot of work, but worth saving some money. Reply |
0RepliesFri Mar 21 2025 | Exit alarm Hi have a Hillrom Versacare P3200 The patient exit alarm won't arm on either side , any advise. Equipment: Hillrom - VersaCare Reply |
0RepliesTue Nov 19 2024 | Disassembling Where can I find someone to disassemble my VersaCare Bed P3200 near Bowie Maryland. It is presently to heavy to carry upstairs nd setup in bedroom. Equipment: Hillrom - VersaCare Reply |
[list] [*] Low bed [*] Lowchair® position allows patients to more easily egress from a chair position [*] "Brake not set" alarm [*] Frame and mattress integration for superior therapy/safety performance [*] FlexAfoot™ mechanism [*] Enhanced Turn Assist (on A.I.R. surfaces only) [/list]
| Height | 37 in high position |
| Bed Type | Electric |
| Length | 86 in Fully extrated |
| Weight | 500 lbs |
| Width | 40 in with siderails up |
