Asclepion - MeDioStar NeXT
by Asclepion
The MeDioStar NeXT takes laser hair removal to a whole new level, with state of the art technology to ensure a fast, virtually painless procedure. The MeDioStar NeXT is one of the most powerful high-speed laser hair removal devices on the market today, the XL model is able to treat an entire average male back in around 5 minutes! The device’s dual wavelength combines with smooth pulse technology to quickly and comfortably treat a wide range of skin concerns. Fiber bundle delivery ensures the flattest beam available. Contact skin cooling is performed by a peltier cooling chip which monitors skin temperature providing greater patient comfort than the standard sapphire cooling system for laser hair removal.
0RepliesTue Dec 13 2022 | Machine doesn't go to ready mode.Displays cooler timeout fault. Dear all!, I am facing problem in Mediostar next machine which is about 10years old. The machine doesnot enter in ready mode.Machine displays error cooler time out fault.I request u to guide me I also request you to kindly share more details about chiller module and normal temperature of R1 and R2 of the cooler module. Thanks in AdvanceReply |
1ReplyTue Sep 14 2021 | Touch screen My device touch screen is not working. Can you guide. If needed can u send a new or refurbished touch screenReply |
| Laser Type | Diode |
| Height | 60 cm |
| Length | 46 cm |
| Weight | 35 kg |
| Wavelength | 800 - 950 nm |
| Width | 36.5 cm |
Pulse duration: Up to 400 ms Delivery: Fiber bundle array, sapphire tip Frequency: Up to 12 Hz
