Syneron-Candela - Vbeam Perfecta
by Syneron-Candela
The Pulsed Dye Laser delivers an intense but gentle burst of light into selectively targeted areas of the skin. Its light is absorbed by specific blood vessels or melanin pigmented areas in the dermis depending on the condition being treated. Factors such as the age, color and type of lesions, as well as the location on the body, all determine whether lesions can be removed.
1ReplyFri Jan 26 2024 | problem to transform fluence for starting to work with vbeam is it needed to set applications or can change parameters without setting or changing applications? Equipment: Syneron-Candela - Vbeam Perfecta Reply |
1ReplyMon Apr 11 2022 | Fault 1.2 Canister bubble Circuit Test Failure My device is showing Fault 1.2 Canister bubble Circuit Test Failure.What might be the defective?What might be the probable solution for it?Anyone please help me Reply |
2RepliesThu Mar 14 2019 | Dye kit replacement Anyone have the procedure to replacing rhe vbeam perfecta dye kit. Please need it urgently.Reply |
[list] Treatments Provided for: [*] Acne Scars [*] Facial & Spider Veins [*] Leg Veins [*] Pigmented Lesions [*] Rosacea [*] Scar Treatment [*] Striae (Stretch Marks) [*] Vascular Lesions [*] Warts [/list]
