Lumenis - LightSheer DUET
by Lumenis
Rethink the Business of Hair Removal
Lumenis revolutionized the Gold Standard LightSheer with vacuum-assist technology and by dramatically increasing the spot size to 22 x 35 mm.                                 The LightSheer enables you to treat backs and legs comfortably in only 15 minutes, making hair removal profitable without anesthetics and gels.
FORUMSView All (18)
-AAD
7 months ago
Service manual
Need service manual for this unit
Equipment: Lumenis - LightSheer DUET
-Amy ghatit
a year ago
Leaking from the bottom
Troubleshooting
-Christelle van den Berg
2 years ago
Service manual
Filling up the water tank
[list]                [*] Two optimal wavelength 800 nm diode hair removal systems on one versatile platform  [*] Permanent hair reduction from all areas of the body  [*] Reduces pain while increasing efficacy  [*] Fast and comfortable treatments    Dual Heads  [*] LightSheer ET  > 9 x 9 mm spot size      > Fluence up to 100 J/cm2   > ChillTip™ continuous contact cooling      > Pulse widths up to 400 ms      [*] LightSheer HS  > 22 x 35 mm spot size      > Largest spot size of any diode      > Integrated vacuum-assist technology      > Pulse widths up to 400 ms      > No cooling or anesthetics required     [/list]
