Lumenis - Quantum
Lumenis IPL Quantum LaserThe Lumenis IPL Quantum laser is a complete solution for cosmetic skin treatments. This system is remarkably versatile and can be expanded and customized to meet your individual needs. If versatility and the ability to upgrade your system are important, then the Lumenis IPL Quantum could be the perfect choice for you. This IPL therapy machine can handle just about any type of skin procedure and you can add on to this system as your needs change.
FORUMSView All (5)
0Repliesa year ago | Water leak I’d like to get a manual so I can repair a water leak. I’ve had this repaired in the past but the fix never lasts long Equipment: Lumenis quantum Reply |
4Replies2 years ago | Opening IPL Headpiece Hi, How do you open IPL headpieces for Lumenis Quantum? I have several of them and I just sacrificed the most worn out one to see how its put together and Ive found its glued?? Is there any way to release that glue? Do you use a heat gun or something else? Thanks for any insightsReply |
7Replies3 years ago | water flow (153) My machine is stating cooling error or water flow and add water but the water is coming out of the bottom of the machine is this an east fix please?Reply |
[list] [*] “No downtime,” non-ablative treatment [*] Treats the full face, chest, neck and hands for a more youthful looking appearance [*] Two second repetition rate and large spot size provides quick procedure and high patient throughput [*] Pre-determined parameters and touch screen control for simplified operation with full parameter versatility available for customised individual treatments [*] Contemporary, compact design with light, easy to hold treatment head and integrated contact cooling Touch Screen Promotes Intuitive Operation Applications: [*] Vascular Lesions [*] Pigmented Lesions [*] Tattoo Removal [*] Leg Veins [*] Hair Removal [/list]
Wavelength | 560 - 1200 nm |
