Hematology Analyzer
he CELL-DYN Emerald 22 Hematology System is designed to be a full performance solution for smaller laboratories seeking greater productivity under tighter space limitations. Startup and shutdown can be programmed to occur automatically each workday. Zero daily maintenance required.
For [i]in vitro[/i] diagnostic use only.
Ask a New Question0Replies-phixante Mon Jan 26 2026 | Mon Jan 26 2026LIS interface Guidance
Hi can anyone provide me the LIS interface guidance for emerald cell dyn 22 analyser? Equipment: Abbott - CELL-DYN Emerald 22 Reply |
1Reply-Kelley Benson Sat Dec 20 2025 | Sat Dec 20 2025Maintenance sheet
Can someone scan a maintenance sheet in? Someone used the last one and I cannot find another one. Thanks Reply |
1Reply-abaseer_3792 Wed Jun 14 2023 | Wed Jun 14 2023External Printer
Which external printer is compatible with the Emerald 22? How do I connect / configure it? Equipment: Abbott Emerald 22 Reply |
- Optical Flow Cytometry technology
- Electrical impedance
- Absorption spectrophotometry
- Electronic valves
- Cyanide-free lyse reagent
- LCD color touch screen
- RS232 and TCP/IP LIS interface
- USB ports
- Up to 45 samples per hour
- Up to 300,000 records on external USB thumb drive
- Operator-defined patient limits for high and panic values
- System-defined limits for reportable range and analytical measurement range
- Suspect parameter flags caused by interfering substances or sample abnormalities
- Suspect parameter flags generated when WBC data indicates possible presence of an abnormal population
| Height | 13.8 in |
| Length | 13.8 in |
| Weight | 24.2 lbs |
| Width | 9.8 in |
- Search by date or sequence number
- Flagging for patient limit sets
- Flagging for panic values
- 1,000 records with histograms on internal memory
- Customizable patient limits
- Customizable report units (USA, SI, SI MOD)
- Barcode reader (reads code 128, code 39, interleaved 2 of 5, and others listed in the Operator’s Manual)
