Alma Lasers - Remove
ALMA BEAUTY REMOVE is a highly effective laser hair removal solutionUsing an 810 nm gold standard diode laser, REMOVE is the worlds best-selling laser hair removal technology, found in over 3,500 clinics worldwide.
Laser hair removal is a high-end, professional-grade hair removal method and is among the most effective treatments in the industry for achieving smooth and beautiful hair-free skin.
The combination of Almas 810 nm diode laser with patented SHRTM technology makes REMOVE the safest, most reliable and most effective laser hair removal solution available today.
- Compact ergonaomic lightweight design
- Unique facial tip makes hard rech ears more accessible
- Disposable hygienic tip for treating intimate areas
Laser Type | Diode |
Height | 45 cm |
Length | 47 cm |
Weight | 40 kg |
Wavelength | 810 nm |
Width | 56 cm |
Spot size: 12×10 mm, up to 10 J/cm2, up to 10 Hz
Power Supply: 120/ 230 VAC, 50/ 60 Hz, single phase
