Alma Lasers - Remove
by Alma Lasers
Using an 810 nm gold standard diode laser, REMOVE is the worlds best-selling laser hair removal technology, found in over 3,500 clinics worldwide. Laser hair removal is a high-end, professional-grade hair removal method and is among the most effective treatments in the industry for achieving smooth and beautiful hair-free skin. The combination of Almas 810 nm diode laser with patented SHRTM technology makes REMOVE the safest, most reliable and most effective laser hair removal solution available today.
[list] [*] Compact ergonaomic lightweight design [*] Unique facial tip makes hard rech ears more accessible [*] Disposable hygienic tip for treating intimate areas [/list]
| Laser Type | Diode |
| Height | 45 cm |
| Length | 47 cm |
| Weight | 40 kg |
| Wavelength | 810 nm |
| Width | 56 cm |
Spot size: 12×10 mm, up to 10 J/cm2, up to 10 Hz Power Supply: 120/ 230 VAC, 50/ 60 Hz, single phase
