PhotoMedex - LaserPro CO2
by PhotoMedex
The LaserPro CO2 laser is designed for applications in Gynecology, Otorhinolaryngology, General Surgery, Urology, Neurosurgery, Plastic Surgery, Dermatology, and Veterinary.
0RepliesFri Dec 03 2021 | Center Image How do I center image on consoleReply |
0RepliesWed Mar 08 2017 | Error C5 RF, PCB, Power Distro Board check out ok. Is the problem from the coolant dip stick or the Laser Power Supply. Problem was intermittent only when the laser was bumped. Now it is constant. Any suggestions?Reply |
[list] [*] Up to 40W in Continuous Mode ( Up to 20W in SuperPulse Mode ) [*] Reliable Construction and Performance [*] Built with the Quality and Durability that PhotoMedex and SLT Lasers are known for [*] Extra Long (1.8m) or Long (1.5m), and Robust Articulated Arms for Operating Room Surgical Applications [*] Quiet Operation; Compact, Mobile, Transportable Design [*] Simple, Intuitive User Interface Panel [*] Choice of Red or Green aiming beam [/list]
| Laser Type | C02 |
| Height | 45 yd |
| Length | 16 in |
| Weight | 190 lbs |
| Wavelength | 10600 nm |
| Width | 16 in |
Laser Modes: Continuous or SuperPulse Treatment Modes: Continuous, Single Pulse or Repeat Pulse Maximum Average Power: 40 Watts (Continuous Mode) 20 Watts (SuperPulse) SuperPulse: 400 microseconds Laser Activation: Foot Pedal Controlled
