A dec - Cascade
by A dec
Adec 1040 Cascade
The Adec Cascade 1040 is an electronically controlled, hydraulically powered dental chair. Buttons on both the touchpad and 8-button footswitch are used to position and program auto-positioning functions into the chair. The hydraulic system is controlled by electronic module using relays and solenoid-actuated valves.
-Susana Faria
2 years ago
How much pressure (Bar)
Hi! As I’m installing a new compressor in my dental unit, I will need to know at what pressure my chair should work. Can’t find the information in this manual. Thank you in advance.Reply
3
-Celios
8 years ago
No water pressure to assistant side
For an A-dec Cascade delivery system:
Have examined components but cannot determine what is causing the low pressure on the assistant side air/water syringe. I have ruled out the handpiece and any handpiece accessories. 40 PSI is coming out of floor box pressure gauge.
  • Double-artculating headrest
  • Backrest casting
  • Automatic armrest
  • Cascade chair swivels 60 degrees (30 degrees each side of center)
  • Programmable footswitch
  • Cast aluminum baseplate
  • Hydraulic cantilever system with stop plate shut-off
Patient Weight Capacity300 lbs
