GE HealthCare - Optima MR450w GEM
by GE HealthCare
The Optima MR450w with GEM Suite MR system combines a patient-embracing caring design with insightful MR technology.
The Optima MR450w with GEM Suite continues to have emphasis on patient comfort without compromising quality or capabilities. It combines the benefits of wide-bore imaging with GEM, or Geometry EmbracingOptima MR450w 1.5T with GEM Suite Method, incorporating an approach to MR imaging that reflects the importance of conforming the geometry of the equipment and technology to that of the patients.
  • 70cm Patient Bore
  • Bright inner bore lighting and a flared gantry lead to a comfortable, open experience
  • High Resolution In-Room Operator Control (IROC)
  • Fast exam set-up with high-resolution color console mounted on the front of the magnet. Easy to see patient, system and scan information, and control and select parameters in real time right in the room
  • Sleek dual-sided controls
  • Control the scanner from either side of the table. Simplify patient set-up with easy access to cardiac or peripheral gating leads and IV lines
  • IntelliTouch Patient Positioning
  • Boost exam productivity with IntelliTouch patient positioning, by eliminating the need for laser alignment and reducing the steps to position patients in as little as 30 seconds.
  • LED accent lights
  • The parenthesis accent lights on the sides of the Optima MR450w enhance the overall aesthetic appeal of the system.
Clinical UseWhole Body
Gantry (Max. Clearance) 70 cm
Magnetic Field Strength1.5 T
